Thread: Help with Pentair Easy Touch remote - cannot connect
    Mar 2017
    Houston
    2
    Hi. I am new to the forum, but I found this troubleshooting an issue we are having with our pool remote.
    It says it cannot connect. We have done everything we can think of to reset it and have replaced the batteries. The guy who helps service our pool *thinks* the issue is with the card attached to the antenna on the control panel (I think I'm putting that correctly).
    Anyone have any ideas? Is this something we can fix ourselves? The guy who helps us just says order a new system, but that doesn't seem right.
    Thanks in advance!!
    Mar 2017
    Houston
    2
    Re: Help with Pentair Easy Touch remote - cannot connect
    To clarify, it is saying "NO COMM".
    I found a few things to try online. I have gone to the master panel to send the address and tried receiving the address via the remote. I also shut down power to the pool equipment entirely and then did the address send again. No luck.
    Thanks.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Hey Amy, welcome to the forum!
    It's been a while since this happened to me right after ours was set up, but I remember for sure that resending the address from the main took care of it. Sorry I'm no more help, but I remember how frustrating that was, and my PB was out of town of course. Pentair told me that, and it worked.
    Essential Links:
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,270
    Amy,
    Sorry, but I have SceenLogic, so I'll be of no help with this issue, but I know someone that might.. I'll let him know he's wanted..
    Thanks for posting,
    JoyfulNoise's Avatar
    May 2015
    14,085
    Check the antenna that connects to the main panel. Make sure all the connections are solid. The antennae (both for ScreenLogic and the RF remote....looking at you Jim!!) are susceptible to getting fried by power surges and what not. You might need to replace it.
    You may need to put a call into Pentair for more advanced troubleshooting as they can walk you through the detailed diagnostic menu.
    Matt
