You have two relay plugs that connect to the main board.
Top plug controls the relays going to Filter, Lights, Aux1 and Aux2.
Bottom plug controls Aux3, Aux4, Aux5 and A6.
Seems like the first four relays are not responding. I would suspect that the plug might be loose.
If the filter relay and lights are staying off, then a loose plug seems likely. If they're stuck on, then maybe a bad main board not turning that set on/off.
Are the relays on or off?
Do Aux1 and Aux2 work?
You can check if the relays are getting 24 vdc to the coil and if the relays are opening and closing.
The display board has connections at the display board and the main board, check both.
Check configuration to see if everything is correct.
Did you get the exact same display as before?
