Results 1 to 7 of 7
Thread: aqualogic display glx localpsa8 board all functions wont work
    Mar 2017
    Angleton
    3
    i replaced my aaqualogic logic display ps 8 board and not all functions work the heater, spa to pool , cleaner all work but the lights and to turn actual filter on/ off wont work the display says on or off the the actual filter stays on whats up?
    30.000 gallon pool, inground, gunite , haward sand pump, aqualogic automation, changed from salt to chlorine, 10 years old, live in southern texas
    Oct 2007
    Valrico, FL
    556
    Re: aqualogic display glx localpsa8 board all functions wont work
    Probably the main board is bad.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    mas985's Avatar
    Pleasanton, CA
    11,986
    Welcome to the forum.
    Did you replace the display or the main board?
    Try re-seating all the connectors.
    Mark
    Mar 2017
    Angleton
    3
    aqualogic ps8
    replaced psa display board (aqualogic ) some functions work and some dont working: heater, cleaner pool to spa not Working: poool filter and lights any ideas on what is going on?
    Mar 2017
    Angleton
    3
    replaced the display how do you reseat connectors?
    mas985's Avatar
    Pleasanton, CA
    11,986
    The display unit has a wire that connects to the main board. Remove the connector and plug it back in to make sure the connection is solid. Also check the wires that connect to the plastic connector to make sure there isn't one that is loose.
    So what happened to the original display unit?
    Were these function operational before the swap?
    Was the replacement a used display unit or a new one?
    Mark
    You have two relay plugs that connect to the main board.
    Top plug controls the relays going to Filter, Lights, Aux1 and Aux2.
    Bottom plug controls Aux3, Aux4, Aux5 and A6.
    Seems like the first four relays are not responding. I would suspect that the plug might be loose.
    If the filter relay and lights are staying off, then a loose plug seems likely. If they're stuck on, then maybe a bad main board not turning that set on/off.
    Are the relays on or off?
    Do Aux1 and Aux2 work?
    You can check if the relays are getting 24 vdc to the coil and if the relays are opening and closing.
    The display board has connections at the display board and the main board, check both.
    Check configuration to see if everything is correct.
    Did you get the exact same display as before?
    Support the site
