Results 1 to 10 of 10
Thread: travertine - is it supposed to be sealed??
    Feb 2017
    Arizona
    26
    We're currently having travertine installed around our new pool. Is it supposed to be sealed?? Also, I think the color is too light; with the sealant, will it darken it permanently? Does the sealant make the travertine too slippery?
    In-ground Arizona free-form pool; 35 ft x 16 ft; depth: 3 ft / 5.5 ft / 8.5 ft; 22,985 gallons; 15-inch Baja step, approximately 8x11 feet; Kona Blue Pebble Radiance finish; Walnut travertine; Autumn Leaves stacked stone; in-floor cleaning system. Build start: 2/2017. My pool pics: https://www.troublefreepool.com/thre...ild-in-Arizona
    Jul 2015
    Central Valley CA
    1,171
    Re: travertine - is it supposed to be sealed??
    It does not have to be sealed but if you are going to have a salt water pool it might be a good idea. It will also mitigate staining from organics, trees, food spills ect. Changing the color and texture depends on the sealer used, a penetrating sealer will not make it slippery and may or may not darken it. Best way to know for sure is get a extra piece from the installer and test it with the product you plan on using. Someone will be along shortly with suggested products I know may choose to seal.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, 320 SQ/ft Powerstrip solar, Stenner pumps for chlorine & MA connected to Smart Life WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jan 2015
    Anthem, AZ
    188
    You're the first person I've seen with my same travertine design. I loved mine. Unsealed with salt pool for 3 years.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,155
    It's a matter of preference if you seal it or not. There isn't a right or wrong about it.
    One of the biggest advantages of sealing it, is the sealer the deck will stay looking beautiful for longer. And when it does come time to clean the deck, it will be easier to do.
    A downside of sealing is that you'll have to re-seal every few years.
    There are a ton of sealers on the market and many have different appearances. Some may make the travertine look darker while others won't and many sealers have non slip additives already mixed in. You can also add your own non slip additives if you want to.
    The best thing you can do for yourself, is learn what's out there, and then make the best choice of sealer.
    Personally, I think that adding a sealer is best.
    My deck is sealed and I have other concrete surfaces around my house that are not sealed in comparison to my deck, they look horrible. I will be sealing those this spring after I pressure wash them.
    Quote Originally Posted by katierose View Post
    Divin Dave,
    Feb 2017
    Arizona
    26
    A tile guy came and sealed one piece; I wasn't crazy about the look. And I discovered water "pools" on top of the sealed travertine; whereas on the unsealed pieces, the water soaks right in. Thoughts?
    Jan 2015
    Anthem, AZ
    188
    try the stuff yourself from home depot or lowes.
    Sep 2013
    Nashville, TN
    412
    We sealed ours with the DuPont sealer after noticing some stone erosion on the coping. We haven't seen any new damage since.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    31,166
    I don't have an opinion on sealing or not.
    I can tell you that many, many sealers will not hold up to the UV they are exposed to in a pool deck and will not last maybe more than one season, if that.
    Jcvader99's Avatar
    Feb 2018
    Charleston SC
    26
    Sorry to wake up an old post, but I am wondering if any others have had good/bad opinions on sealing the Travertine lately? Ours is new, from April, and I am wondering which route to take?
    I DON'T want slippery, nor water pooling on top, but I also don't want it to look like old crusty tile in a year or two.
    Anyone done it lately, or have new thoughts, regrets, other??
    Completed 12-April 2018 * 24'x36' IG Free-form Gunite * 3.5' to 5.5' deep
    Wet-Edge Signature Matrix "Picasso Blue" * Hayward SWCG * Polaris TR35P Vacuum
    Hayward Pro Logic+TouchScreen Pod Remote * Hayward TristarVS Pump
    Hayward 6060 Booster * Hayward SwimClear Cartridge Filter * FT-100 Test Kit + SpeedStir
    Travertine Coping & Deck * 3 Deck Jets * 2 skimmers * 16,100 gallons
    riley00dog's Avatar
    Nov 2017
    Brisbane, Qld, Australia
    2,184
    We had our travertine professionally sealed upon the insistence of our pb. He wouldn’t warranty anything to do with paving if we didn’t. We were given the choice of three different brands and multiple products by the company. They were all penetrating sealants and do not alter the look or feel of the paver. We went with the Lithofin. The product we chose has a 25 year warranty. No reapplication required in that time. We were also provided with their care products. We were strongly against sealing but are really glad we were forced into it. I would have thought we would have very little in the way of bird droppings etc in our small pool area. I was wrong. So much bird poo often with a purple berry colour. Even bat poo despite never seeing a bat here in my life. I try to clean things off as soon as I can. I typically just use a bit of pool water and a kitchen brush. Nothing stains so that is a relief. I have compared with a spare paver and there is zero difference in colour, feel or slip.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
