Thread: How much for in-ground spa?
    Feb 2017
    Arizona
    26
    We're in the middle of a pool build (no spa). When we initially met with pool builder, we were told a spa would be an extra $15K. Does this sound right? Wishing now we would've added one.
    In-ground Arizona free-form pool; 35 ft x 16 ft; depth: 3 ft / 5.5 ft / 8.5 ft; 22,985 gallons; 15-inch Baja step, approximately 8x11 feet; Kona Blue Pebble Radiance finish; Walnut travertine; Autumn Leaves stacked stone; in-floor cleaning system. Build start: 2/2017. My pool pics: https://www.troublefreepool.com/thre...ild-in-Arizona
    Sep 2016
    Dallas, Texas
    188
    Re: How much for in-ground spa?
    Quote Originally Posted by katierose View Post
    Certainly don't know if it's apples to apples but I inquired what the cost reduction would be to LEAVE OFF my 6.5 x 6.5 attached spillover spa from my pool as I was spec'ing it out and was told the cost reduction would be approx. 6,500 dollars.
    Hope this helps.
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    A spa can add 15k to 20k to the cost of the pool depending on lots of factors. We saved around 15k or 18k by deleting the spa from our pool build. For our build it deleted a heater, pump, automation and the extra gunite, coping, tile, etc associated with the spa portion of the pool.
    We bought a standalone spa for $5700 the next winter and put it on a covered patio that ended up being inside a screen porch. Standalone tubs are more comfortable, cheaper to operate, always hot on standby, covered and all around better in my opinion.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Our 7x7 square spa was 10500 which included stone (not travertine)
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
