Thread: Question for a chemist
    May 2015
    Cape Cora, Florida
    2
    Why is reverse osmosis water so hard on copper pipes? Does it make acid while it is leaching the metal out of it?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Question for a chemist
    RO water is aggressive because there is very little of anything in it mineral, or buffer wise. Roughly, waters are either scaling or corrosive. If they contain little to nothing, they will dissolve many things they come in contact with. Metal or mineral. Water is always trying to reach equalibrium by dissolving or depositing something. It won't create acid, but some RO water is on the acid side, say 6.0-6.5 depending on how far it is processed.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Welcome to TFP!
    May 2015
    Cape Cora, Florida
    2
    Thank you very much. Question came up over on solarpaneltalk I didn't quite know how to answer it. I just know it's very hard on copper pipe.
    DFW, TX
    24,974
    It is mostly about PH, pH below 7.0 is corrosive to copper and pH above 7.2 is not.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    RO is agressive to most minerals and most metals. Copper is highly suceptible to some things like Chlorine, and like Aluminum it is also susceptible to elevated pH levels.
    Essential Links:
