- Dec 26, 2016
- 34
- Plaster
- CircuPool RJ-45 Plus
I recently had my pool renovated which included replacing all valves. The technician decided to remove the spring and valve from the old spa common Ortega check valve (horizontal type that looks like a "T") and placed a new Jandy check valve in front of the old check valve. He explained that by removing the spring and valve, the old check valve would act as a normal 90 degree turn. He didn't want to replumb this part of the circuit because the spa common check valve was so close to the ground (only a few inches from where the pipe goes underground).
Does the removal of the spring and valve from the check valve impact water flow significantly? It seems that without the spring and valve, the water would enter the dead-end part of the "T" of the old check valve and create water turbulence that would impact the flow significantly. Or perhaps the hydrodynamics work such that when the dead-end part of the T is filled, water will flow down uninterrupted.
thanks.
thanks.
