Thread: Determining Number of Gallons
    Feb 2017
    El Paso, TX
    42
    Renting a house in which the owners know nothing about the pool, including its gallons. I've been using a rough estimate of 16,000 suggested by another forum user, but I am having trouble getting my chemicals straight. The final readings, after adding chemicals according to PoolMath, are always higher ( i.e. FC should of raised to 5 but was at 6 or 7/ pH should of raised to 7.6 but it's 7.8 or 8)
    I have a free form pool with three different depths and a spillover spa. My question is, what is the best way to get an accurate amount of gallons and to determine the length and width of the pool?
    Thanks, Kelsey
    Plaster, 2 HP WhisperFlo Pump, DE Filter
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Determining Number of Gallons
    The easy way is to adjust your volume based on the discrepancies you've already noticed, maybe going 500 gallons at a time.
    If you want to do it the "hard" way, here you go: A Chemical Way of Calculating Pool Volume
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Feb 2017
    El Paso, TX
    42
    That's what I figured and have been doing. I believe I'm getting closer as the discrepancies are getting smaller and smaller.
    May 2011
    lebanon tn
    370
    Quote Originally Posted by ChelseaSoccer View Post
    Thanks, Kelsey
    If Fcu goes to 6 plus instead of 5, I'd drop 1000 gal. 6 is 20 percent over 5 so decrease of 15-20 percent should be safe initially. Then500 next time if needed
    May 2011
    lebanon tn
    370
    Sorry. 2000 initially would be about 16 prrcent
    Feb 2017
    El Paso, TX
    42
    Thanks for the feedback. I'll give it a go tomorrow and let you know.
