Thread: Pool Leak Repair - Northern Illinois
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    This might go out to a narrow crowd, but any Northern Illinoisans have any experience with companies repairing below grade pool piping? I am about 60 miles west of Chicago, a little west of Elgin. My 1.5" skimmer line leaks when the pump is off. I started seeing air in the pump basket while vacuuming a few seasons ago. I attempted a "Fix a Leak" repair by "pressurizing" the suction line involving a quite drawn out process. That helped, but the leak is back. I have 1.5" black poly transitioning to PVC at the pump pad just below grade and assume the same type connection is on the bottom of the skimmer. This is where i believe the leak is and is of course under concrete. I confirmed the leak by closing the valve to the skimmer and plugging the skimmer drain, operating the pool via main drain only. After a day or so, when I remove the skimmer drain plug, air will burp out of the line as it refills - so it definitely leaks. At it's lowest point - idk, but it burps air for a while.
    Google searches bring up some companies that can scope the pipe but none that can line the pipe, as offered in some southern areas. It will probably boil down to just breaking out the concrete, repairing, then replacing the concrete, but I don't want the unsightly patch lines. Unfortunately there are no places to hide a patch unless I remove much more concrete than necessary to reach the skimmer. Questions:
    - Any experience with local companies
    - Replace all existing black poly with rigid PVC, about 40' most of which under concrete.
    - Or just redo connection on skimmer (preferred method - silicon and barb w/clamp?)
    Picture is the best I had. Hope it helps. Thanks!
    Attached Files Attached Files
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    wjr75's Avatar
    Jun 2013
    IL
    866
    Re: Pool Leak Repair - Northern Illinois
    I use Platinum Pools out of Wheeling for a lot of repair stuff and they also open and close my pool. They have fixed many leaks for me in the past. There are companies that will pressurize your lines with some sort of epoxy to seal leaks in underground plumbing. I think there is a company up north somewhere. Not sure how this process works since I never had to try it.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Pool Tool's Avatar
    May 2014
    757
    I appreciate the response. Yes, I was hoping that there were some companies around to try and seal first before pulling the concrete. I will keep looking/calling around.
