Thread: Blower needed for 2 therapy jets?!
    Feb 2017
    Orlando Florida
    13
    Ok. I had a pool built and the builder "forgot" to put the blower in. They said they would put it in or credit me the cost back. I have two water bowl fountains also and was wondering if I add the blower would it have any effect on the two therapy jets or fountains. The builder says it provides enough power which seems like it when I turn them on. Just curious , thanks
    mas985's Avatar
    Pleasanton, CA
    11,984
    Re: Blower needed for 2 therapy jets?!
    First, welcome to the forum!
    If the jets work fine without a blower, then you don't need it. I have 6 jets that operate just fine without a blower. Personally, I wouldn't want to use a blower if I didn't have to. They are noisy and use a lot of energy.
    Mark
    Dec 2014
    Riverside California
    494
    I have 6 jets in my spa, and when I turn my Intelliflow up to 3K rpm I get a lot of flow into the spa from the jets. If I turn my air blower on in addition to the 3K pump, it blasts water right out of the spa onto the deck. When I had my old single speed motor, the blower might have been needed, but not with the 3 hp Intelliflow.
    I might disconnect the air blower and gain an Easy Touch relay for some additional landscape lighting.
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    Feb 2017
    Orlando Florida
    13
    Thank u for your input !!
