Thread: Does adjusting CH affect salt level?
    Apr 2016
    Dayton, Ohio
    31
    If I need to add 25-30 pounds CaCl2 to get my CH back to 350 or so after winter partial drain and rain and snow refill, will that affect the salt level I measure with strip test for salt or for Taylor salt drop test. Obviously I am not adding sodium but is all the extra chloride contribute to measured salt level? Just wanting to account for that if needed when adding salt in a couple weeks to open pool.
    Thanks, John.
    26,000g IG, Fiberglass side/Concrete bottom, epoxy paint, Pentair IC40 SWG, Pentair Cartridge Filter 420, Pentair Intelliflow 3 HP VS pump, Pentair 120 Heat Pump, pool installed 11/2015, painted and equipment installed 4/2016. City Water.
    Re: Does adjusting CH affect salt level?
    25 lb calcium chloride is roughly equivalent to 20 lb salt as far as chloride levels.
    Support the site
