Results 1 to 8 of 8
Thread: Intex pool opening
    Jun 2016
    Brunswick GA
    11
    Intex pool opening
    We have a 5000 gallon aboveground Intex pool. We live in Georgia and when we got this latest storm our pool cover blew partially off. We noticed our pool was growing bugs and was completely green. We hadn't been adding any chemicals to it over the winter. So I started the filter back up and have been following the shocking procedures outlined on this website. I had to readjust all of the chemicals and the only one I have not done yet is the calcium hardness because I need to get to the pool store to get some. It's 150 currently. We have been vacuuming still as well because there is a lot of debris on the bottom of the pool however after vacuuming for a bit you can no longer see anything so we have to stop. My water is now very cloudy. How do I get it clear again?
    Intex Ultra Frame 15' x 48", 40" depth, 4,440 gal., 110-120V Filter Pump, flow rate of 1,000 gal/hour, filled with garden hose. I use a Taylor K-2005 test kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Intex pool opening
    Welcome to the forum!
    I would suggest starting over with a full drain, clean, and refill if it were mine. However, if you want to SLAM it (follow our shock procedure) you need a proper FAS/DPD kit for testing Chlorine, and I don't see thst listed in your signature.
    Before vacuuming more, try netting/skimming or otherwise removing all the debris you can. The limited filtering capacity you have with this type of pool will be a major hindrance if its really dirty. If you choose the latter route, we will be here to help you through so just let us know.
    Essential Links:
    Jun 2016
    Brunswick GA
    11
    I have the dpd chlorine test with the powder for exact chlorine numbers.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Ok, great!
    If you want to clear it by clean and SLAM, then follow the procedure in the SLAM article to the letter. If you do that it wont fail. Let us know how we can help.
    Essential Links:
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    If you are trying to clear the pool with the intex cartridge filters then use a stocking over the cartridge to help clear it quicker. Also clean the filters daily
    When I had cartridge filters I had two sets, so I could just swap in a clean one and then clean the dirty one, ready to swap in the next day
    See if you can alter your filter output to really swirl the pool water around. That helps consolidate the debris to the middle of the pool for easier vacuuming
    When you vacuum go as slow as you can, so you dont kick up as much of the debris
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    domct203's Avatar
    Jun 2015
    CT
    3,905
    Quote Originally Posted by Mtuccolo View Post
    Your signature in your first post list a Taylor K-2005 DPD test kit. That is not the same as the FAS/DPD test kit we recommend as the DPD only reads FC up to 10ppm, and is a color match test which is not accurate enough for the OCLT & CC measurements.
    Is your test indeed the color matching DPD K-2005, or is it the drop counting FAS/DPD that we recommend?
    Can you please post a complete set of test results including:
    FC
    CC
    pH
    TA
    CH
    CYA
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2016
    Brunswick GA
    11
    Yes I do you have the one with the powder that gives you the exact amount of free chlorine and combined chlorine by counting the number of drops. I didn't realize my test kit didn't come with that so I bought it separate. I have to test the pool water tonight so I will post numbers then.
    domct203's Avatar
    Jun 2015
    CT
    3,905
    OK great! Looking forward to those test results.
    Dom - TFP Guide
