Thread: Easytouch Breaker Labels?
    Flybriz's Avatar
    Apr 2010
    Tulsa, OK
    43
    I've seen several photos of Easytouch load centers in the forum with nice black labels next to the breakers to identify lights, heater, pump, etc. I wrongly assumed that these were included with the Easytouch system. Would someone please share where you've sourced these labels? Thanks!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,291
    Re: Easytouch Breaker Labels?
    Fly,
    I used a standard P-Touch label maker.. It works ok, but I was not all that impressed. Of course it could have been just operator error...
    JoyfulNoise's Avatar
    May 2015
    14,086
    You can find actual Pentair labels on Amazon but they're overpriced. If you have a P-Touch label maker, Brother sells tape for those that is "outdoor" compatible and will last a bit longer than their regular labels.
    Most people use Sharpie markers, not elegant but way cheaper than the alternatives.
    Matt
    Flybriz's Avatar
    Apr 2010
    Tulsa, OK
    43
    Thank you both! I have a Brother P-Touch at work. I'll give the black tape/white print a try. No way am I paying $90 for labels!
