Thread: AGP on Sloped Concrete
    Feb 2017
    Parkville/MO
    1
    Hi Everyone-
    I have a large back driveway that is slightly sloped away from my home... I had the driveway replaced a couple years ago and it is in great shape but it slopes ever so slightly to move water away from the house...
    So, last year I had a 14 round Summer Escapes metal frame AGP on it and didn't level it and it was off about 2 inches... it didn't bother me a bit, I just use the pool to float around, no kids in it playing, etc.
    I want to up my game and put a 24' X 12' X 52" Intex AGP back there this year. It is this exact pool:
    https://www.amazon.com/gp/product/B0...d_i=1272958011
    I've been thinking a lot about the various ways to level this pool on concrete and I need some advice please.
    Do you think I could get away with just putting varying sizes of wood blocks under the leg/supports?
    For reference, here is a photo of where I am going to put it... It will fit perfectly with 1 foot remaining on each side b/c my driveway is 30 feet wide.
    The house is a reverse ranch, with the garage door on the left of that image. The drive slopes away from house and also slopes slighly out to the left from the house... if my math is right, it is about 6 inches drop from one end to the other.
    Would propping up the legs/feet supports be enough to do the trick? I know that I should probably build a frame and level it with sand, etc. I'm really looking to do this as minimalist as possible.
    Any advice is greatly appreciated!!!!
    Thanks!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: AGP on Sloped Concrete
    Welcome to TFP!
    Unless someone has a better idea, I'm thinking a sand base is the best way to handle this. It will also need to be very firm, stable, and well protected from any possible erosion and washout from rain fall etc. I would plan carefully on this one.
    Essential Links:
    Apr 2013
    Sacramento, CA
    2,769
    I agree with Patrick. I'd lay down a sand base, a couple inches thick minimum and two feet larger than the pool. Use compactable sand.
    The pool is designed so that the water pushes against the wall evenly. The water inside the pool acts as a structural element of the pool. With blocks the walls might be level but the force of the water against the walls would not be even.
    aboykin2269's Avatar
    Jun 2015
    Charlotte NC
    225
    Definitely need to level the bottom. Raising the legs on the low side will only raise the legs. The pool itself will not be level and you will put more strain on the low side. Think of it like this, you raise the legs, but you are not going to lift 40K+ lbs of water. You will be stretching the sides and could have catastrophic failure.
    Speaking from experience here. Good luck and keep us posted as to what you decide.
    Ant
    16'x48" Summer Escapes Pro-Series, AG, Ultra-Frame, Intex CS15110 Sand filter/SWG, 5061 GAL, TF-100 Test Kit w/ K-1766 Salt Test and Speedstir.
    Pool School, ABC's of Water Chemistry, CYA/Chlorine Chart, Water Balance for SWG's, Pool Math.
    Jul 2015
    Central Valley CA
    1,166
    I was thinking sand as well, perhaps a bender board a couple feet past the pool to keep everything in place, You could even put some fake grass down on that will give you a clean entry in and out of the pool
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
