Results 1 to 8 of 8
Thread: King Fin Brush
    Atlanta, GA (Dunwoody)
    62
    King Fin Brush
    Anyone have experiance with King Fin Brush? Wondering how reliable, life, and does it work well
    Heinsite
    17500 pool/spa iAqualink Rev R, Pentair VSF, Pentair DE Filter, Waterfall, 3900 Polaris Cleaner, Goldline Saltwater Gen. w/t15, Rayvac 40,000 Gas heater, Taylor K-2006 Test Kit, Taylor Saltwater Test Kit
    JoyfulNoise's Avatar
    May 2015
    14,083
    King Fin Brush
    Quote Originally Posted by Heinsite View Post
    Sent from my SM-G935V using Tapatalk
    If it's anything like the "Wall Whale" brushes I love mine and it's been working for 4 years now. I probably need to replace the brush head this season but the fin still works fine.
    I think the fin style brushes are excellent and very effectively mix the water. Just be careful and go with a normal size. Wall Whale at one point made this XL style brush which was a very dense brush that was extra wide. It generated so much downward force and friction that most people could barely push it.
    Matt
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: King Fin Brush
    I was scared of getting a brush with too big of a tail. We can't be working too hard! I got this brush and it works great. A fin definitely helps.
    Paradise 18 Turbo Brush Swimming Pool Brush | PTB100
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,151
    King Fin Brush
    That looks like a spoiler that you could have glued on the back of a Chevy Cavalier back in the day.
    I have the WW regular size. Nice pressure.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    DFW, TX
    24,974
    Re: King Fin Brush
    Yep, it's a cute little guy.
    62
    Re: King Fin Brush
    Thanks for the input. I ordered one off ebay (king-Fin) and will update my evaluation of it after using awhile.
    Heinsite
    62
    Re: King Fin Brush
    Brush work fine. Can one hand push forward and one hand pull if a long pull. As you shift from pushing forward, the brush float up. The bottom line is that it does add pressure to your brushing, but you can't go really fast. For $24 it's good but we'll have to see how long it last
    Heinsite
    May 2011
    Long Grove, IL
    131
    Re: King Fin Brush
    My experience with this brush is mixed. The brush itself works well but the springs on the fin are total crapola. I had only used my brush a few times and one of the springs broke. I called the company and was told no warranty on the springs but was happily informed that I could purchase a replacement set (left and right springs) for something like 5.00. I went ahead since the brush was useless without the springs and it was essentially new. Well I was using it yesterday and only got halfway around the walls of my pool (20x40 NOT Olympic sized) and another spring broke. I don't know which spring it was but with any luck it will be the spare spring I have.
    In any event, I wouldn't buy one again. Too high a probability that another spring will soon break and I will be out another 5 bucks or left with a useless brush.
    I should add that I hate brushing and only do it a few times a season so overuse is NOT the problem and my water is always balanced so it isn't as if the water is attacking the stainless steel springs.
    Regards,
    Jay
    Jay
    28,000 gal in-ground hybrid pool with PacFab Superflow 100 sand filter witn VitroClean media, Intelliflo VS pump, Stenner chlorine pump, Raypak R336A Millivolt Natural Gas Pool Heater
