Thread: Should my salt chlorinator adjust my PH
    Feb 2017
    Australia
    20
    Hi
    ive got a salt chlorinator cell, acid dosing etc
    my PH has been set at 7.4, yet actual has been 6.7 for days.
    my orp is set at 610 mV
    my chlorine is reading as high
    should I chuck in some PH increaser chemicals....
    or make adjustments to my system.....?
    cheers
    23000 litre salt chlorinated pool, fibreglass in ground with 1500litre spa
    Jan 2012
    'burbs of Augusta, Georgia
    8,585
    Re: Should my salt chlorinator adjust my PH
    I think I'd do my own chemistry test to determine what the water *actually* is, as the machine may be far off. I never make changes to pool chemistry based on mechanicals. I trust my TF-100 test kit over all.
    If that water truly is 6.7 (or lower) I'd be chuckin' something in there for sure!!! You need to fix that *yesterday!*
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jan 2017
    Orlando/FL
    124
    What do you use for "Acid Dosing"? You said it was set for 7.4. Does that mean the device you have measures the PH and corrects the dosage to maintain 7.4?
    I have an acid dosser too (mine is a dumb device, it just inject the same amount of acid each time, so I have to set dosing adjustment by trial and error).
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
