Thread: freed1b
    Sep 2015
    Ontario
    1
    freed1b
    Hi all my pool builder is also recommending Jandy products see below- is that equipment a good choice? Also what would be better - an automation with PDA or skip the PDA and go with a wifi and phone app aproach. Any help is appreciated.
    Jandy 1 variable speed pump
    Jandy 340 cartridge filter
    Jandy JX126 260000btu
    Jandy Aqua pure digital salt system
    Jandy automation and PDA
    Thx for your help
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    Re: freed1b
    Welcome to TFP! Good to have you here
    Jandy seems to be in the top recommended brands here, and they absolutely make great pool valves.
    In my signature below this post, there's a link "read before posting" which includes tips for getting the best possible advice here. One is to add your pool size (gallons, dimensions, shape), if it has a spa, mention that, and anything else you'd like to add. That would help people chip in.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,265
    Re: freed1b
    Free,
    Welcome to TFP... A Great resource for all your pool questions..
    In my opinion, the key to a good automation system is having the same brand of equipment for all the electronic equipment that needs to talk to each other, like the pump, the SWCG and the control center. All the major brands are about the same, so it becomes a "my Chevy is better than your Ford" type of thing..
    I have Pentair system, which allows me to use my phone, tablet, or computer to control the pool. To be honest, I use the PC a lot, and almost never use my phone. But, I don't have a Spa, and that might be the reason why.
    Thanks for posting,
    Aug 2014
    Houston tx
    2,542
    Re: freed1b
    Also, you might want to consider going with a larger cartridge filter and salt system. I have the Aquapure 1400 and only need to set it at around 10-15% to maintain my chlorine level. That means it runs less and is less wear on the cell. A larger cartridge will mean less cleaning. My heater is also 400,000 btu. You need to get model numbers for all of your equipment so we can really see what you are getting.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Jul 2016
    Prosper, TX
    20
    Re: freed1b
    With phone and computer access, I fail to see a need for a dedicated third device to control the pool. Make sure you clearly define what all you expect to control independently up front. I was in for a surprise when my 'I want to control the pool features from my phone' only meant lights and pumps when it was all said and done. It wasn't an expensive oversight on my part, but could have been depending on original controller choice.
    Jul 2014
    Bedford, TX
    9,265
    Re: freed1b
    Free,
    bard has hit the nail on the head... If the infrastructure is not built into the pool, it does not matter what type of control system you get..
    So if you have a waterfall and a bubble, and the pool builder put them on one pipe, then after the pool and deck is in it might be impossible for you to control them independently..
    Automation is not magic, it can only control what is controllable..
