Results 1 to 11 of 11
Thread: Shocking the pool
    Jun 2012
    Austin, TX
    48
    Shocking the pool
    Ok so this might be a dumb question, but am I supposed to shock the pool at a certain interval even though the pool water is fine? We have had our pool for 2 years now and are about to start the third season (90 degrees in Feb in Texas this year) and I was wondering if I should shock or not. We haven't had any problems with the water at all and the pool looks as sparkly as ever. When talking to my neighbors, they say they shock their pools every week so I was wondering if there is something I am missing.
    16.000 US Gal. w/Spa; freeform gunite; built 2015ish; Pentair Quad DE filter; 3 HP Pentair VS Pump; 2 skimmers, 1 main drain, 4 returns, 15 Gallon Stenner Tank, 45MHP2 3GPD Pump, Dolphin Triton Pool Cleaner. TF100 Test kit!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,916
    Re: Shocking the pool
    LOL no it is what THEY are missing-A good test kit! IF your water is balanced using TFP levels and your testing and you keep the levels there you are DONE! They, on the other hand, HAVE to shock to keep ahead of the algae. After a while they will get their CYA so high they will lose the "race" and get a full blown algae bloom!
    Kim (sneak over they are grab a bottle of their water and share the results with us)
    Jun 2012
    Austin, TX
    48
    Lol. Thanks Kim! I talked one neighbor who just installed a pool into doing the same stenner tank/pump setup for bleach that we have. They saw how low maintenance our pool was and wanted to do the same thing. As for the others, I tried to talk about how I do it, but they seem to prefer to go to the pool store all summer. I even did a CYA check for one family on my street and it was way over 100. They still decided to go to Leslies to get what the needed to "fix" it.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    I have to say that you are doing better than most. It's often hard to get even one person to see the light and you have done it!!
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Quote Originally Posted by kimkats View Post
    Agree with this. I was told to shock weekly by the pool store and ended up with +200 Cya. Keep doing what you're doing and get Kim a water sample. Trust the kit.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Quote Originally Posted by pabeader View Post
    And isn't it a great feeling when you have a convert? I lent my TF-100 to a friend/coworker and got my first convert. But in truth, most don't listen.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jun 2012
    Austin, TX
    48
    Quote Originally Posted by AimeeH View Post
    I told my one converted neighbor to get the TF-100 kit. They just finished the pool and the builder gave them a kit without CYA tests..
    Jan 2012
    'burbs of Augusta, Georgia
    8,557
    Quote Originally Posted by holmern View Post
    yeah, and the FC test probably tops out at 5 too. <sigh> A cheap-o test kit isn't that helpful from a pool builder yet the way they make it sound as if they're throwing in some amazing perk.... <eye roll>
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    The old "shock once a week routine"... Yes, that's one of the most common myths we bust over and over. You'll be ever so pleased to find it simply isn't true. Welcome to the sparkly side of pool care.
    Essential Links:
    Jun 2012
    Austin, TX
    48
    Quote Originally Posted by Patrick_B View Post
    Thank you sir. I've been browsing here for a few years now. Started reading about it before we built our pool. Had ours for 2 years now with perfect pool water and I have been amazed to see how easy it is.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Right on! I haven't "shocked" my pool since I filled it 5 years ago. Or drained it, had a green swamp, missed a swim day ever, etc. Thanks TFP!
