Pool is an inground gunite with the following specs: 17,500 gallons, jetted SPA, solar heated (8 panels). Controlled by an Aqualogic system with a T-15 cell and cartridge filter.
We are very much considering either a 2-speed or variable pump in the coming months due to our electricity bills here in Florida... they are averaging about 400/month with the pool pump running about 8-9 hours a day.
The following components were just replaced (FYI) - the Aquarite MAIN PCB (with new firmware that supports variable speed), the T-15 cell, the flow switch and believe it or not - the pump motor.
Reading some of the stories about VS pumps and how sensitive the electronics are to lightning makes me a bit sketched out here in Florida... but perhaps a 2 speed pump is a better solution.
What's the general consensus here? Leave it alone and let it run until the next failure?
regards,
doug
regards,
doug
