Hi,
I've had my pool for 2 seasons. I live in MN where we get cold winters and harsh conditions. I have alot of wind in my backyard. I closed my pool in the fall with directions from this website. I switched this past year from a 27' winter cover to a 24' winter cover with wrap.
It is just starting to warm up a bit here with temps in the 40's with mid 50's coming this weekend. We will most likely drop down and probably will get more snow storms before spring is here. Last year I opened mid April when temps were around 60.
I just noticed today that my walls have buckled much much worse this year compared to last season. I've taken a bunch of pictures and uploaded them here:
pool wall buckling - Album on Imgur
As you can see I have buckling all the way around the pool. The worst appears to be buckling at the lower portion of the metal plate where the skimmer is. I contacted the store where I bought the pool and talked to their service department today. They had me send pictures and told me to immediately remove the wrap and cover and put it inside the pool to relieve pressure on the walls. The service manager said this winter has been unusually harsh here with many deep freeze/thaw cycles that caused alot of ground heaving in the area. He thinks I may have this under the pool causing the low level buckling. He has suggested I leave the cover in the pool until it gets closer to opening and then contact them again for evaluation. The only thing he suggested I do is try to dig down near the edge of my pool and try to see if the wall is still within the ring it was installed in. If not he said it would be a complete teardown/rebuild for $1000-1200 including a liner replacement and assuming they can re-use all my parts.
I'm wondering what the forum experts here suggest. I didn't do anything different this year for closing compared to last year except using a more appropriate sized winter cover (24' for 24' round pool). I was told this was just mother nature and bad luck.
Any suggestions what I should consider here?
Thanks in advance.
Thanks in advance.
