Hey all. .I did some research on this but I'm still confused. I just moved into a new house that has an older (1980's) inground pool with attached spa. The spa has both the regular sized pool return jets as well as 4 large "hot tub jets". The pool-size jets work just fine. I can fill or drain the hottub, it heats up, etc .. but nothing comes out of the jets. If I put my hand over them, all 4 feel *very* slightly like they are sucking water.
Do you think they're not hooked up to anything? I checked around for what might be an air pipe and I found several candidates. Not sure . .would it be located near the pumps . .or near the spa? If near the pumps then I think I found it and it's filled with water . .looks like rain water.
Basically . .I have no idea, lol. It seemed like the other pool/spas I saw in my researching had only the large spa jets . .or else they didn't show/make mention of the regular-sized jets.
Thanks for any thoughts/ideas!
