Since the only way to reduce CH is to drain and refill (or perhaps an expensive reverse osmosis treatment), and given you're in AZ, you're not going to lower it a whole lot by draining - you don't have a target CH. You simply track it so that you can keep an eye on your CSI number - which will let you maintain your pool balance to prevent scaling (or prevent destroying your plaster). So 450 is fine - leave it alone.
Right now, your water is likely quite cold. This means I personally wouldn't lower the pH to 7.2 - you're likely going to want to leave it higher to avoid your CSI dropping to a point where the water starts leaching calcium out of your plaster. While the normal SLAM guidelines have you lowering it to 7.2, I'd be tempted to leave it at 7.8 -please wait for an expert to weigh in on that statement. MOD note: You got it right! No need for anyone else to say anything!
The rest of your getting ready looks pretty good to me.
