I have 1HP Whisperflow pump setup for my waterfalls (and available for future water features), and a separate pump for the pool filtering.
I want to install a Pressure Side Pool Cleaner that normally would require a Booster Pump.
The 1HP pump has a 2" return line directly to pool with an adjustable valve to control the flow to the waterfalls (I can have all water from the pump go the water falls, or I can open the valve some and let some water return to pool to reduce waterfalls). So I can control the flow to a Pressure Side Cleaner. I would not be able to control the water pressure though.
The specs on this Whisperflow pump say it can flow around 90GPM at 30ft dynamic head (way more flow than a Booster Pump has). A typical Booster Pump is rated around 50psi @ 12GPM.
Will this pump operate a Pressure Side Cleaner?
I have more than enough flow (GPM) but I don't know what PSI I would be at (the pump on the filter side runs around 20psi). Do I need high pressure and low flow to run a Pressure Side Cleaner?
I've looked at a couple of Pressure Side Cleaner manuals, and none say what the required flow and psi need to be for the Cleaner to operate.
BTW- there is a Pressure Side Cleaner (Legend II) available that does not need a Booster Pump (will operate directly off a pool return fitting), but the Polaris model I want says it needs a Booster Pump.
Thanks
Thanks
