Results 1 to 9 of 9
Thread: Newbie to TFP
    Jan 2017
    El Cajon
    6
    Cool Newbie to TFP
    Hello, I am Coobie and I just registered here at FTP. I am fairly new to the pool world as well. We purchased this home in June 2016 and have been learning ever since. I have no way of knowing the size (gallons) of the pool, but I can tell you in my area (Southern Ca) it seems to be larger than most residential pools. It is a bit older, mid to late 80's if I would have to guess. I would like to modernize it in the future.
    Had some issues right away when the pool pump took a dive (pun intended). Since it was no longer working I did a little research and ended up purchasing a Pentair V/S pump. We had solar installed on the house and while we were making that deal, I had them install a pool solar thermal unit on my patio roof. This combination is one reason why I joined this forum, look forward to posts asking questions about Pentair settings, proper speeds, replacing a pool light, calcium removal, and more!
    Thank you for taking the time to read my intro! I look forward to learning from all of you.
    Coob
    Dec 2016
    Covington, LA
    34
    Re: Newbie to TFP
    Welcome! Great looking pool. I'm new here as well, and have learned quite a bit in the couple weeks since I have been here. Follow the link below and start creating a signature. Provide as much information as you know, and fill in the rest as you learn.
    Trouble Free Pool
    14K Gal, In Ground Vinyl, Hayward Pro Series Sand Filter Model S244S, Century Centurion 1hp Switchless Pump with a PB4 Cleaner Booster Pump, Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder, Taylor K-2006C, Currently maintained every 2 weeks by a pool service
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    29,289
    Re: Newbie to TFP
    HI! You seemed to have done pretty well up to now! It is not green! LOL
    I have a tool for you! There is a learning curve but what I want you to use right now is the size helper part. We will work on the other stuff as you learn more about TFP. https://www.troublefreepool.com/calc.html Look towards the bottom. You will see a size estimator. We will work on tweaking your size as we work though everything.
    How have you been testing your water up until now?
    So glad you found us!
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Re: Newbie to TFP
    Welcome to TFP!
    Jan 2017
    El Cajon
    6
    Re: Newbie to TFP
    Quote Originally Posted by kimkats View Post
    Kim
    Testing...uh yeah.
    Y'all are gonna kill me but all I've been doing from advice from somebody who's brother's uncle's neighbor is a pool guy kinda thing is add 1G Chlorine and 1G acid every week. Regular brushing
    Using the pool calc, it looks like my pool is approximately 31,500 gallons.
    Thank you for that, I've always wondered.
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: Newbie to TFP
    Mods, can we please please have a facepalm emoji, because seriously I can think of no better response!!
    Oh well Coobie, lets look on the bright side and move forward. Your pool is not green, yay!!. You brush regular, which is a good habit. You know you dont know enough about pool maintenance, so you joined here, awesome move that one, you wont regret it
    However the most important part of pool care, is to test your water yourself and add only what is required to keep the water safe and sanitary for swimming and to protest your pool surface and equipment. You need a test kit. We recommend a Taylor K2006C or the TF 100 Test kit from TFTestkits.net. The preferred is the TF100 and if you order that one, get the speedstir as well, I hear its awesome and makes testing really easy.
    https://www.troublefreepool.com/cont...its-comparison
    Oh and hi and welcome to TFP
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Jul 2012
    Tallahassee, FL
    29,289
    Re: Newbie to TFP
    Quote Originally Posted by Coobie View Post
    1G acid every week.
    THIS is the one that scares me the most! Do you mean 1 gallon of Muratic acid??? a week????? Please say no but do not lie to me LOL
    Now,now, now Caco........pat, pat, pat.......He is here and ready to learn. Right Coobie?
    That IS a big pool! WOW! The more I look at it the better I like the design.
    Coobie, here is what we need you to do please. Set up your signature. Go to settings (upper right) then to edit signature (middle left). Fill in kind and size of pools. Equipment details such as kind for filter (sand, DE, cartridge), pump size, etc.
    Once you do that please go to my siggy and look at the link that talks about test kits. This is the number one tool for taking care of your pool. It will save you money in the long run AND your pool will look even better than it does now!
    I can't wait to see your test results so we can start getting the pool looking like it can with TFP!
    For right now please do not add anything to your pool other than a 1/2 gallon of chlorine.
    Kim
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,127
    Re: Newbie to TFP
    Welcome to TFP! My brother's nephew's cousin's mother-in-law used to know a guy who's dad was a poolie, so we have heaps in common!
    Good to have you here
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Re: Newbie to TFP
    Welcome!!! You will LOVE it here I started my adventure on TFP with an INTEX above ground swamp and then relocated back to SoCal and rented a home with a pool Knowing what I did from here, I convinced the landlord to fire her pool guy and let me take over... haven't turned back 2 years now and at least she trusts me when I talk to her about anything wrong with equipment etc...
    You will wonder why you never did it before lol
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
