Results 1 to 10 of 10
Thread: Need help with seal kit
  1. Back To Top    #1
    Join Date
    Mar 2016
    Location
    Easley, SC
    Posts
    289
    I am rebuilding my pool pump and need guidance on what all I need. I have the motor apart and the bearings removed and new ones in hand. I need help with the seals needed to put it all back together. Attached is my motor and basket label.
    Sent from my SM-G900V using Tapatalk
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
  2. Back To Top    #2
    mas985's Avatar
    Join Date
    May 2007
    Location
    Pleasanton, CA
    Posts
    10,317
    Re: Need help with seal kit
    I am not sure what you are asking because the seals have nothing to do with the bearing installation. Just remove the old bearings with a bearing puller and press on the new bearings.
    Here is the seal kit but the seal goes on after the motor is installed in the motor plate:
    Amazon.com: Hayward Super Pump Complete Pump O-Ring Rebuild Kit, fits all Models: Patio, Lawn Garden
    Mark
    Hydraulics 101; Pump Ed 101; Pump/Pool Spreadsheets; Pump Run Time Study; DIY Acid Dosing; DIY Cover Roller
    18'x36' 20k plaster, 1/2 HP 2sp pump, Aqualogic PS8 SWCG, 420 sq-ft Cartridge, Solar, 6 jet spa, 1 HP jet pump, 400k BTU NG Heater
  3. Back To Top    #3
    Join Date
    Mar 2016
    Location
    Easley, SC
    Posts
    289
    That is what I was looking for. I was only stating replacing the bearings so everyone would know how torn apart it is and what I needed to reassemble. I also found a water slinger seal, is that needed?
  4. Back To Top    #4
    mas985's Avatar
    Join Date
    May 2007
    Location
    Pleasanton, CA
    Posts
    10,317
    Yes, you can replace that too if needed.
    Mark
  5. Back To Top    #5
    Join Date
    Mar 2016
    Location
    Easley, SC
    Posts
    289
    The one that came off was two rubber washers and a steel washer. Guess the single washer is an update? So that kit above has everything else needed?
  6. Back To Top    #6
    mas985's Avatar
    Join Date
    May 2007
    Location
    Pleasanton, CA
    Posts
    10,317
    Yes but I changed my mind, use this kit instead:
    https://www.amazon.com/Hayward-Compl...GY7T83Z2Z8Y5B7
    It has better seals.
    Mark
  7. Back To Top    #7
    Join Date
    Mar 2016
    Location
    Easley, SC
    Posts
    289
    How can you tell it has better seals? Just so I know what to look for.
  8. Back To Top    #8
    mas985's Avatar
    Join Date
    May 2007
    Location
    Pleasanton, CA
    Posts
    10,317
    It uses US Seal. Crane are also good seals.
    Mark
  9. Back To Top    #9
    Join Date
    Mar 2016
    Location
    Easley, SC
    Posts
    289
    Thanks!
  10. Back To Top    #10
Posting Permissions
  • You may not post replies
  • You may not edit your posts
