Results 1 to 10 of 10
Thread: Need help with seal kit
    Mar 2016
    Easley, SC
    381
    I am rebuilding my pool pump and need guidance on what all I need. I have the motor apart and the bearings removed and new ones in hand. I need help with the seals needed to put it all back together. Attached is my motor and basket label.
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    mas985's Avatar
    Pleasanton, CA
    11,743
    Re: Need help with seal kit
    I am not sure what you are asking because the seals have nothing to do with the bearing installation. Just remove the old bearings with a bearing puller and press on the new bearings.
    Here is the seal kit but the seal goes on after the motor is installed in the motor plate:
    Amazon.com: Hayward Super Pump Complete Pump O-Ring Rebuild Kit, fits all Models: Patio, Lawn Garden
    Mark
    Mar 2016
    Easley, SC
    381
    That is what I was looking for. I was only stating replacing the bearings so everyone would know how torn apart it is and what I needed to reassemble. I also found a water slinger seal, is that needed?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Yes, you can replace that too if needed.
    Mark
    Mar 2016
    Easley, SC
    381
    The one that came off was two rubber washers and a steel washer. Guess the single washer is an update? So that kit above has everything else needed?
    mas985's Avatar
    Pleasanton, CA
    11,743
    Yes but I changed my mind, use this kit instead:
    https://www.amazon.com/Hayward-Compl...GY7T83Z2Z8Y5B7
    It has better seals.
    Mark
    Mar 2016
    Easley, SC
    381
    How can you tell it has better seals? Just so I know what to look for.
    mas985's Avatar
    Pleasanton, CA
    11,743
    It uses US Seal. Crane are also good seals.
    Mark
    Mar 2016
    Easley, SC
    381
    Thanks!
    Deleted.
    Support the site
