Results 1 to 13 of 13
Thread: Lo message.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Lo message.
    I have cleaned filters and pressure switch is new last 6 months. Water temp is in the 50's. Spa heater fires up but filter keeps running sending water out of spa to pool.
    18,000 gal. Inground plaster. Pentair FNS Plus DE 48sq ft. 1 1/2 hp pump. Pentair Mini Max NT spa/pool heater. Automated w Goldline control pad inside and Aqua logic main control panel outside . Test strips and weekly pool store water testing. Attached spa w waterfall. Polaris 280 sweeper. Pool over 10yrs old.
    Sep 2016
    Dallas, Texas
    188
    Re: Lo message.
    Quote Originally Posted by Tmkowalski View Post
    Not quite enough info to know what all is happening...have you opened the spa drain valve to allow water to return?
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,044
    Re: Lo message.
    Tm,
    More info and a picture of your equipment pad would help....
    Am I correct in guessing that the Spa is overflowing into your pool and that you want that not to happen? If so, then the valve on the input pipe to your pump must be set to the "Spa" only position. And the valve on the "Return" side must be set to "Spa" only position.
    Do you have some type of automation? Where are you reading the "Lo message"?
    Thanks for posting,
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Lo message.
    Figured it out. The spa skimmer valve wasn't turning. I did it manually and waterfall stopped. Spa started to heat up immediately. Why didn't valve move automatically? Trying to attach pix, file too large.
    ps0303's Avatar
    Jul 2011
    FL
    3,577
    Re: Lo message.
    There is a small toggle switch on the back side of the actuator. See if by flipping that switch makes it turn one way or the other. If it doesn't turn no matter which way you flip it, then the motor inside is probably broken and you need to replace the one.
    Paul
    http://www.gastekservices.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Lo message.
    What is the actuator? And where?
    The spa skimmer valve is the one not moving.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Lo message.
    Figured out Acuator. Toggled switch. Nothing happened. Motor bad?
    Jul 2014
    Bedford, TX
    7,044
    Re: Lo message.
    Tm,
    The actuator sits on top of what you are calling the "Spa Skimmer" valve and it is what electrically moves the valve. If you have automation, it should be connected to the actuator via a small cable about the size of a pencil..
    The switch is on the back of the actuator and it has three positions. Left, right and middle. The middle position is off, so you do not want to leave it there.
    Tm,
    Could be a bad motor, or could be no power from your automation system.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Lo message.
    Figured all that out thanks. Motor seems bad. Pool place says I have to replace whole black box unit. Can't just replace little round motor inside. Is that true. Appreciate your help. I can hear buzz when I flick switch and no noise when I turn switch to off, so I'm getting power to unit.
    Jul 2014
    Bedford, TX
    7,044
    Re: Lo message.
    Tm,
    Not sure if you can even buy the motor, but if me, I'd replace the entire unit..
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Lo message.
    Do you know the part #? I'm trying to look it up.
    Tmkowalski's Avatar
    Feb 2015
    San Antonio Texas
    34
    Re: Lo message.
    Looks like they're more than 100.00. I have AHS insurance that I pay 100.00 max to fix. May be better off using that.
    ps0303's Avatar
    Jul 2011
    FL
    3,577
    Re: Lo message.
    Yes you might be better off using them since the cost of a new one is close to the $100 deductible you pay.
    Paul
