Thread: Starting up
    Starting up
    33 ft round AG pool will be installed Sat. How long will it take to fill it up ??
    Also I am thinking about trying the BBB method after reading alot of good info.
    I am going to order the test kit here online.
    What do I need to add to pool since it will have no chemicals in it ?
    Any advice appreciated, Thanks.
    Above ground 33 ft round 52 in. high
    Approx. 25000 gallons
    Hayward Dreamline Sand filter holds 250lbs sand
    Hayward CL-200 chlorinator
    Hayward 1.5 hp 67 GPM pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Starting up
    how many gpm's does your hose run? 3-5 probably. how much does your pool hold? you tell the width but not depth. I would guess 4ft but not sure. anyway the answer, as well as most everything else you need to know can be found below. (the answer to volume is found at the bottom of the the pool calculator. link is in pool school).
    pool-school/
    Re: Starting up
    Dont know about the gallons per minute . depth would be 4 ft, Referenced 25000 gallons in signature ( if I did calculation correct ). Thanks.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Starting up
    You will certainly want stabilizer (CYA). After that, it depends on what's already in the fill water; post test results and we'll see what's up. Until then add a small jug of Clorox to the pool each evening to help keep anything bad from getting started.
    --paulr
    BBB "Intermediate Swimmer"
