I'm considering installing a Stenner pump for bleach injection. I have a pretty small patio area, with my Weber S-660 stainless steel grill well away from the pool. The pump/filter are a bit closer to where the grill is located.
Does anyone know how much distance I need to have between the grill and a Stenner tank filled with bleach to keep fumes from collecting under the grill cover and eventually causing corrosion/rust?
Thanks.
Thanks.
