Thread: Added borates, rise in pump pressure
    May 2009
    Sacramento CA
    13
    Hi all
    I added the borates and MA to the pool today. Now the pump pressure has gone up approx. 12lbs. Is this borates in my cart or just dirt from sweeping. OK to clean?
    Thanks Steve
    20K gallons,plaster, IG, Posi Flo 100 cartridge filter, 3/4hp pump. , Polaris 280?
    Re: Added borates, rise in pump pressure
    If you were adding borax to the skimmer, you should give it overnight with the pump running to dissolve and then see what you filter pressure is.
    May 2009
    Sacramento CA
    13
    Hi again,
    I added the borates to the pool near a return line, not the skimmer.
    Also, the pressure is still rising. Could I run the polaris to help stir the water?
    Thanks, Steve
    Since you added the borates to the pool, you should clean the filter.
    Guest
    Neither borates or muriatic acid will cause the filter pressure to rise but if you had any algae in the pool the borates would kill it and THAT could cause your pressure to rise.
