Results 1 to 11 of 11
Thread: Little balls you put in skimmer that act like solar cover?
    I have a heater and a solar cover for my pool. A friend was telling me that they got some little ball that they put in their skimmer and it lasts for a month and acts as a solar cover for the pool. I can't imagine this working but she said when they night swim and jump in the pool the area that they jumped into is the only place that they can see the heat escaping. Just wondering if anyone has tried them?
    19600 gallons.. Viking fiberglass pool... 1.5 horsepower Hayward sand filter... Aqua bot turbo....Heat pump
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Little balls you put in skimmer that act like solar cover?
    I have never seen them myself . But some others may have and will answer soon
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Guest
    They are plastic balls that contain the HeatSavr liquid and are called the Solar Pill. They work about as well as the solar fish and the plain HeatSavr liquid (which is not very well at all, IMHO)
    Sep 2008
    The Woodlands, Texas, USA
    243
    They were a waste of money for me. Use your cover. It works much better.
    IG 24k plaster with overflow spa. Goldline PS-8 SWG. Tristar 0.75 HP filter pump, Polaris 280, large cartridge filter, 400k BTU NG Max-E-Therm HD, SR Smith Turbo Twister, Life Saver pool fence, ORP managed.
    That is exactly what I thought... Thanks so much for responding!!
    I'm currently using the pill now as my solar cover was torn off the pool by the wind. I followed the instructions and put the pin in and put it in the skimmer as was instructed. It said after 4 hours all the liquid would have been released into the skimmer. NOT!!! I had to hold it above the skimmer and let it drain out. I have no idea if they work or not although you can detect it on the surface, but seriously I have no idea how one would know.
    all they do is empty your wallet...
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    bdenehy's Avatar
    Mar 2008
    Putnam Co., NY
    15
    I know a lot of posters are anti-liquid solar cover and I'm sure you are right, but right now I'm trying to cut down on heating costs, even if just a little. In that line, does anyone know if I can manually add Liquid Heat daily, without buying/installing an expensive automatic feeder? I have a pretty large pool surface (~1025 Sq ft) so I would need several of those expensive little balls at a time. What I would like to try is to just add 2.5 (1 oz. per 400 sq ft) ounces of the bulk Liquid Heat into the skimmer basket each day with a medicine dropper for a while and see if I get any improvement. A cover would be hard for me since I have a "free form" type pool and my wife would have a hard time removing "pieces" if I were to cut up/combine two solar covers.
    gabagoo - did you notice any problems from quickly draining the solar ball vs. having it absorb over 4 hours?
    Thanks
    35,000 gal vinyl, Hayward DE Filter, Hayward 400k BTU heater, SWG, Polaris 380 w/booster pump, plenty of dog hair in the skimmers.
    not sure as that was the first time I had used one. I could detect it inthe water over the next 2 weeks and even now I can sort of see it but the weather has been so crappy this year with night time temps dropping so low that I can retain not a lot of heat. I have 2 more balls so I will use them till there gone
    Sep 2009
    Gulf Coast Florida
    13
    heres the deal on any invisible solar cover.....the water needs to be still while using these. Point all the returns down and the heatsaver will work. it is like mercury, if you touch it, it will break apart but as soon as you move away it comeback together.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist $600 w/part of deck included), 13,500 gallons, Intex SWG, solar panel
    My backyard is like a park... Why then does DH always want to go camping??? I just don't understand.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by leak-hound
    Great explanation, leak-hound. I always wondered how this liquid cover stuff worked and apparently, if you get in to actually swim or want to aerate the water... it doesn't.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
