I just have to ask.. Does your pump "pick up" when in backwash waste or recirc?
I'm not 100% sure what you mean, but the pump seems to behave the same when it's backwashing. I don't have a multiport so no recirc, just an old plunger style backwash valve.
Are you thinking that there might be a restriction in the filter?
the pump/filter loses pressure so easily when there's anything in the basket. I've been gone for 2-3 day weekends and come back to skimmer and pump basket that are both pretty full of junk, and yet the pump/filter maintained pressure well over 20-22psi and there was plenty of flow. I never had enough crud in either basket to clog it up so bad that water couldn't flow, even after 3-4 days of being away. The behavior now is that even a small amount of junk in the basket makes the pressure drop fairly rapidly. If I let it go for 2-3 days now I could imagine I'd be down to 8 or 10psi pretty quickly. I have to clean both skimmer and pump baskets daily and 100%, can't leave even a trace of crud in there.
