Thread: Avatar?
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    Avatar?
    I have tried to upload a new avatar, but without success. I saw that the picture has to be no larger than 120x120, but even at those dimension the size is bigger than 9K. Any ideas on how to make a small enough image, so I can upload a picture?
    Thanks
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Avatar?
    that is such a pain I know. what I did was use google's picasa. under the picture you want, there is an icon for Export. if you click that, you can resize it kind of. it's trial and error to get it the right size though.
    Guest
    Re: Avatar?
    If you are using Micro$oft Windoze:
    Use IRFANVIEW (a free graphics program) to resize it and if it's a jpg to save it at a lower quality. That will make the size small enough.
    http://www.irfanview.com/main_download_engl.htm
    Been using it for years now and it's excellent for tasks like this.
    May 2009
    Dallas, TX
    62
    Re: Avatar?
    I usuall just use Photoshop to make images smaller. I read somewhere else that the max size is 80x80 and 5K. I guess I'll have to try that, and if that doesn't work, I'll try picasa. Thanks
    May 2009
    Dallas, TX
    62
    Re: Avatar?
    After failing several times to make the image small enough in Photoshop, I uploaded it in photobucket, and resized it there. I finally have an avatar!
