Explain why this equation works
Jun 14, 2015
6
Dames Quarter, MD
Hi, I was looking for an equation (outside of the pool math calculator) for adding chlorine to my pool and found this:
Initial chl solution * x = desired solution * pool volume
I tried it out on my pool numbers and checked it against the pool math calculator and it appears to work (at least, I should say the results agree). I was trying to think how to explain this, but I can't really seem to articulate to myself WHY it works. Can someone help me out with this? I can't really figure out what the value is that you achieve when multiplying the desired solution by the water volume.
Thanks (trying to improve my long abandoned math skills).
I don't usually go down this road, but I had to test myself. So here's what I got using "5" as initial chl (FC) and "8"as desired FC in a 33K pool:
Initial chl solution * x = desired solution * pool volume .... so ...... we need to solve or find "X":
5 * X = 8 * 33K ..... so ... first complete the right side ... 8 * 33K = 264,000
Then .... 264,000 / 5 = 52,800 ... so "X" = 52,800
To check my work ... 5 * 52,800 = 264,000
Smell that? That's my brain on fire. :) Not sure how this would be helpful, except showing my kids how to solve for "X", so I'll stick to the Poolmath Calculator. :)
It works because both sides are solving for the same thing - essentially the total amount of chlorine.
On the left side is the total amount of chlorine in your bleach
On the right is the total amount of chlorine in your pool
It only works when the measurements are the same (ppm and oz). Honestly I think your own explanation is much more eloquent than mine.
This equation is basically finding the ratio of actual chlorine to volume of liquid. Since the units have to be the same on both sides, then x has to be a volume of liquid (chlorine solution). This formula basically will tell you the amount of bleach to add to increase the pool chlorine by a desired ppm (at reasonable ppm levels). It does not give you the final ppm of the pool water, unless you started with 0ppm of chlorine in the pool.
my opinion is that it is a cumbersome way to figure it out ppm needed.
if you simplify the equation it gets easier though:
Reduced to basic terms:
x (oz of bleach to add) = 0.0128* Pool volume (in gallons) * desired chlorine to add (in ppm)
Initial bleach concentration (in %)
work listed below(lol)
My actual method uses this formula above to make a home made measure cup out of an old used juice container. I have a reliable supply of 10% bleach and I always use the same pool volume in my calculation. This allows me to make the personal measuring cup of sorts. I know that a 1ppm addition to pool chlorine takes 15.4 oz of 10% bleach in my 12,000 gallon pool.
I just took the half gallon juice container (because it was clear) and poured in 15.4 oz of water, and marked a line. This represented the equivalent chlorine to add to increase my pool by 1ppm. I added another 15.4 oz of water and marked another line. I did this 4 times. I then went back and labeled each line with 10%, 1ppm / 2ppm... and actual volume each line represented.
When it comes time to dose the pool, I just fill from the bleach bottle into my personal jug to the appropriate line for the ppm I need. No calculations and easy to measure.
*Changing the bleach concentration changes this method (5.25%, 8%, 10%, 12.5%)
*You can use any size jug you have
*Obviously make sure you label the container so you don't use it for other uses. Rinse well after each use.
similar to this:
http://www.troublefreepool.com/thre...re-your-bleach?p=535690&viewfull=1#post535690
work shown below (lol):
x (gallons of bleach to add) = Pool volume (in gallons) * desired chlorine to add (in ppm)
---------------------------------------------Initial bleach concentration (in ppm)
since it is much easier to measure in oz than gallons:
1 gallon = 128 lq oz.
x (oz of bleach to add) = 128* Pool volume (in gallons) * desired chlorine to add (in ppm)
since bleach is labeled in % Sod Hypo and not ppm Sod Hypo:
1 % = 10,000 ppm
---------------------------------------------10,000 * Initial bleach concentration (in %)
