Thread: FC a little high
    Patrick's Avatar
    May 2009
    Central NJ
    29
    FC a little high
    Is it safe to swim when the FC is 10?
    CC is .5 and everything else is in range (using TF-100)
    Patrick - Central NJ (15th Season)
    19 K Gal. Free Form Gunite/White Plaster Finish
    Nautilius DE Filter (48 sq. ft. grid)
    Whisper 1 1/2 HP Pump
    Pentair MiniMax CH 250M Natural Gas Heater
    Jan 2009
    Cupertino, CA
    1,966
    Re: FC a little high
    FC by itself isn't enough to say one way or the other; it's how the FC relates to CYA that matters. FC 10 with CYA 20 is at shock level and I wouldn't go in. FC 10 with CYA 90 is the high end of the normal range and is no problem to swim in. Check out the Chlorine/CYA chart to help with this decision.
    --paulr
    BBB "Intermediate Swimmer"
    Patrick's Avatar
    May 2009
    Central NJ
    29
    Thanks!
    CYA is at 50.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Jump in,the water's fine!
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
