Motor or Pump not working?
May 19, 2015
145
Burbank, California
So after this discussion. Looking to replace Pool Pump, Need Advice.
I decided to just reduce the number of hours the pool filtered to 2.5 hours per day instead of buying a new pump.
But this recently happened last week.
https://vid.me/6tFR
Any idea what is going on here? Seems like the pump isn't turning on. But how do I know which is actually not working?
Glad you got it working but there appears to be water under the pump. That is usually a sign of a leaking seal. Check to make sure your pump isn't leaking any water while running.
