Thread: Would Bar Bell Weights Be OK?
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Hi all. We have six big round indentions in the bottom of our wedding cake steps and are wondering if we can use bar bell weights (the kind encased in the heavy-duty plastic) and sit one in each of the indentions. Would the chlorine eventually cause the plastic to crack? We looked for the big round cement steps used in landscaping and can't seem to find them anywhere now. But we were concerned about whether we could set plain ol' cement in the water anyway. Any advice would be greatly appreciated.
    DH is concerned that if we hang the AT's (Anna's Tubes!) that the water, when we're in there playing, will knock them around, and shift the steps. So we're thinking maybe just lay some heavy round something-or-other in the indentions instead.
    Thanks.
    32x16 buried Doughboy, 4' shallow - 7' deep
    Pentair Dynamo 1 hp, 2-speed - Pentair 150# SD40 w/zeolite (75#)
    One skimmer/two returns/Aquabot Turbo T2
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    Re: Would Bar Bell Weights Be OK?
    Oops! Forgot to include the picture of the inside of our steps...
    Jun 2008
    Carrollton, GA
    88
    I used the hand weights last year to hold down my step until I got new steps. We had no problems. We did this after a sandbag busted and we had to clean up sand for a few weeks. The new steps came with a huge tube that we filled with pea gravel and sand the screw the stopper in and caulked it with silicone. The tube is suspended between the top and bottom steps and moves with the current so we do not have to worry about algae collecting under steps.
    Susan
    18x33 AGP, BAQUAPURE 200 lb sandfilter, 2 1/2hp Workhorse pump (2 speed)
    Cherie's Avatar
    Jul 2008
    Wylie, Texas
    506
    So Susan, with your tubes moving with the water, it doesn't cause your steps to shift any? That's why we were going with the weight thing. Otherwise, we'd like Anna's and get the PVC pipes and suspend them. Also, about how much weight is needed to hold them down really good?
    Thanks.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Quote Originally Posted by Cherie
    Thanks.
    Thats what I've used for years without any problems.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
