Pump needs priming every morning when pool pump starts
May 25, 2015
8
Weston/FL
Greetings. I have been coming out in the mornings to find my pool pump running dry after it starts. This just started happening only recently. I have a Hayward Max-Flo 2 1.5hp pump. The check valves appear to be functioning ok and there are no detectable leaks. Any idea what could be causing this to happen all of a sudden?
I see it in your profile, just not on your post.
The only reason a pump will drain like that is because there is an air leak. Probably the pump lid gasket or drain plug. Inspect both for cracks and lube with pool lube.
