Thread: Highest FC for testing
    May 2009
    Sacramento CA
    13
    Hi all
    Just shocked pool, how high can FC be and still have accuarate test results. I think I read its different for different tests.
    Thanks, Steve
    20K gallons,plaster, IG, Posi Flo 100 cartridge filter, 3/4hp pump. , Polaris 280?
    Jan 2009
    Cupertino, CA
    1,966
    Re: Highest FC for testing
    Depends on the type of test. The OTO test (drops that turn yellow) generally comes with a color block that goes up to 5; you can dilute your sample half-and-half with chlorine-free water to double the range. The DPD test (drops that turn red) I think works the same way, range-wise; although it tends to "bleach out" at high FC levels (incorrectly reads very low). The FAS-DPD test (powder that turns the water pink, with drops that make the color go away) is supposed to work up to 50ppm.
    --paulr
    BBB "Intermediate Swimmer"
    May 2009
    Sacramento CA
    13
    Hi again,
    What I ment to say was Id like to run all the tests. Will different tests require different FC levels.
    Thanks,Steve
    Jan 2009
    Cupertino, CA
    1,966
    Ah, okay... the pH test starts being unreliable at FC > 10; I hear that high FC can also cause the, uh, I think it's the TA test to turn unusual colors, but if you're just looking for the color to start and stop changing, the exact color isn't important. I don't think anything else cares about FC level.
    --paulr
