Thread: Running out of FAS-DPD reagent
    May 2009
    East TN
    74
    Speaking of the test kit. Does anyone know how long the R-0871 should last during all this conversion and testing every few hours? My bottle seems like its getting low and I've only had it a week. I went ahead and ordered a refill, just incase. Is that normal, I mean since we have been testing a few times a day especially during the beginning of the process?
    Am I correct in thinking that once the conversion is complete and I'm in maintenance mode, we'll just be using the little blue Taylor kit for daily testing and then just use the FAS/DPD test for weekly testing or when we need adjustments?
    Jennifer
    24 ft. AG-approx 13,500 gal
    2 HP sand filter-2 speed
    4ft x 20ft Sunheater Solar Panels
    Re: Running out of FAS-DPD reagent
    It is fairly common to use up a bottle of R-0871 during a baquacil conversion.
    Once everything settles down to normal, you will typically only do a FAS-DPD test once a week, and commonly on lower FC levels. There are some people who like to use FAS-DPD daily, but that isn't required.
    May 2009
    East TN
    74
    Thanks for the info Jason. I thought that might be the case, as much as we've been testing this past week. lol
    Jennifer
    Guest
    Took me two years to go through a bottle of DPD titrant on a pool open year 'round! I do confess that I don't always test it weekly but I DO know my pool and it's been trouble free and stays pretty stable unless we get a lot of rain! Still on the same container of DPD powder btw! It's getting near the bottom but still not completely gone! I do use the OTO/pH tester before I enter the pool or spa each time, however, just to make sure things are within bounds.
    May 2009
    East TN
    74
    Thanks for the info. Good to know.
    Jennifer
    Guest
    I did a conversion from Baq last year and now have to get some new reagents. Chlorine and CYA test reagents go really fast!
    This is exactly what I started doing after conversion. I do a daily pH & chlorine test -- if anything looked odd, I'd do a full test. I had to add CYA a week or so ago (after refilling pool due to partial Fall draining), then we've had rain, so I'll test that over the weekend when everything's clear again.
    Good luck!
    Sue
