Thread: Question on TF-100 T/A test
    Carrollton, TX
    126
    Instructions say to add the R-0009 reagent till the color changes from green to red, counting the drops. At some point the color changes from green to a pink/light pink. It usually takes around 2 more drops to fully change to a full red color. So do I count the drops between the pink color till the color actually reaches red to figure T/A or stop at the pale pink color?
    7000 gallon IG freeform w/ 6 ft. spa, 21 ft weeping wall, Hayward SP4020NS Northstar pump, Colorlogic LED’s, DE6020 filter and H400IDL2 400,000btu heater. Aqua logic 8 zone controller with Aqua Rite salt chlorine generator, Stonescapes pebble finish – Aqua Blue and flagstone coping, stamped/stained concrete deck
    Benton, La
    148
    I go until it is red...
    If you are unsure of the color change you keep adding drops until the color doesn't change any more and then you don't count the drop that failed to change the color. (There must be a better way to explain that.)
    East Tennessee
    278
    Quick reminder...Be shure to mix between drops and wait for a second.. Add drops untill you get a stable color change and subtract the last drop.
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    Quote Originally Posted by medvampire
    Steve
    I would say "add drops until you get no color change"...
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
