Is your water crystal clear without any haziness or fogginess? Was your CC less than 0.5? Just making sure you passed the 3 criteria for completing a SLAM.
You do not raise to mustard levels unless you have mustard algae. Mustard algae is rare. Post up photos if you think you have mustard algae.
If you are using your SWG you need to use the SWG/bottom portion of the chlorine CYA chart that shows Pool School - Chlorine / CYA Chart
CYA 60, Min FC 3, Target 4, SLAM FC 24. Generally many of us keep the FC near target. Your lowest FC level of the day should never reach the minimum. FC 4 is just too close to FC 3, so try to target to keep your FC near 6 or 7. This will give you some wiggle room as you dial in your pools needs.
You generally do not want the SWG generating if you are using the spa only as the FC levels could get too high. I have a spa and I make sure to turn my SWG off when I use it. Mine is oversized for the pool and generally runs at 100%, so it can raise the FC in the spa to very high levels pretty quickly. If you use the spa for a long period of time, you can check your FC levels and if necessary bump up FC using bleach.
I close my pool, but use the spa long after pool season is over. I generally have the water circulate in both the pool and spa and maintain just like the summer. I turn the spa on when I intend to soak and when finished I reset the flow to circulate in both bodies of water. It is much easier to manage one large body of water, vs managing two bodies of water and one being very small. I have a very large gas heater, so it doesn't take long for the spa to heat up.
You'll probably find that you use less FC over the winter months. If the water gets too cold, the SWG will not generate chlorine and you will need to supplement with bleach/liquid chlorine.
