Pump Basket Won't Fill Up (New Pool)
sheree202
249
Lawrenceville, GA
My water level got a little low and my Pentair VS Pump told me that it needed primed. I've filled the pool to a good level but the pump basket still isn't filling. I released the air from the filter. There is no valve at the main drain pipes. I have the skimmerclosed and the return open. Am I doing somethong wrong?
Okay, that worked beautifully. I closed the filter air valve once it started shooting water. As soon as I opened the skimmer valve the pump got air bubbles in it.
The air was probably in the skimmer line since you had the valve closed. Let it run for a bit and make sure it draws nothing but water. That's provided the fact that the pool water level is above the skimmer. ;)
