Thread: pool chemistry
    Aug 2008
    Delaware
    45
    pool chemistry
    Opened my pool 1 week ago,all values were normal at that time;now after adding some water chemistry is off. current values are as follows:
    Temp.-76
    FC->10.0 Any suggestions on where to start would help
    TC>10.0
    CC-0.0
    PH->8.2
    CH-150
    ALK-46
    CA-15
    COPPER-0.13
    IRON-0
    SALT-2500.00
    Susi
    30X14 IG,Vinyl,13,800 Gal
    Hayward-Pro Series Sand filter(Rated flow75GPM/284LPM)
    SWG-Aqua Comfort,Polaris360 Auto Vac
    Re: pool chemistry
    First, lower your PH down to around 7.4, confirm that PH really is around 7.4 (doesn't need to be perfect, but not way off either). Then measure your TA again, and raise TA to about 70.
    With a SWG, you want to raise your CYA level to around 80.
    Your salt level look like it is probably a bit low. Check your SWG manual and raise salt to 100 or 200 above the recommended ideal level.
