Page 13 of 40 FirstFirst ... 31011121314151623 ... LastLast
Results 241 to 260 of 798
Thread: South Florida Pool & Outdoor Living - STARTUP PHASE
  1. Back To Top    #241
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    31,504
    Re: South Florida Pool & Outdoor Living - TILE PHASE
    Filter your are paying for:
    Pentair Clean Clear Plus Cartridge Filter | 160301
    Filter they gave you:
    Pentair Clean Clear Cartridge Filter | 200 Sq. Ft. | 160318
    I have a sad for you
    Let us know how they handle this one.
    Kim (no cheering for this one)
  2. Back To Top    #242
    Jul 2016
    Austin, TX
    349
    The CC200 will work, but you will be cleaning the filter more often. It doesn't look like there is room for the 420 without a lot of rework.
  3. Back To Top    #243
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,887
    That would annoy me. You specified the larger filter so you should get it. But at this point, not only should you get it, but it should not be crammed in. The plumbing pad should be reorganized to properly accommodate the specified equipment. You shouldn't be made to suffer an annoyingly crowded pad forever because the PB installed the wrong filter to begin with. Nor should you accept the current filter and forever be required to clean it more frequently.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  4. Back To Top    #244
    Jun 2016
    FL
    901
    The PB is going to replace the filter with the correct one. I asked that if anything else needs to be moved or changed to accommodate it to let me know so it can be discussed first. The base of the 420 is at least 6" wider so I expect a lot of rework to be done.
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
  5. Back To Top    #245
    Jun 2016
    FL
    901
    Re: South Florida Pool & Outdoor Living - DECK PHASE
    Here's the new filter installed. They definitely did some rework and considering the size difference in the filter it's not too bad in my opinion.
  6. Back To Top    #246
    Jun 2016
    FL
    901
    I'm pretty sure we found our plaster choice. It is Sapphire, a marquis collection color, by Premix Marbletitle. It is a quartz based aggregate finish that rivals Diamond Brite and Florida Gem here in Florida. They have the same 10 year warranty.
    To date, our favorite quartz-based product/color was Diamond Brite Aegean Sea but our PB and applicator does not recommend Diamond Brite and the PB makes customers sign waivers for streaking and mottling with dye-based colors. The Sapphire Marbletite is the closest color we could find and is a grey based plaster which from what I've seen doesnt mottle, blotch, or streak like other color based finishes. I've found that we like most of the colors that a grey base creates.
    Here are some pics of a pool I visited today, in the sun and in the shade.
  7. Back To Top    #247
    Jul 2012
    Tallahassee, FL
    31,504
    It fits!!!!! SWEET!
    That plaster color is one I would pick for me! LOVE it! So glad you got to see it in real life!
    Kim
  8. Back To Top    #248
    Jun 2016
    FL
    901
    Final grading being done today. Also just got our estimate for pool fence which will go in next Saturday.
  9. Back To Top    #249
    Jun 2016
    FL
    901
    Our covered patio construction is just about done. And since the piles of dirt are gone, I finally got a pre-glamour shot. Im imagining water in the pool, pool lights on, and nice green sod and landscaping
  10. Back To Top    #250
    Jul 2012
    Tallahassee, FL
    31,504
    Soon! OH so soon!
    Love it!!
    Kim
  11. Back To Top    #251
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Re: New Build - South Florida Pool & Outdoor Living
    I have not seen this type of bottom before, what material is that? From the pic, it looks like plenty of places for dirt, dust, debris to collect but may be just the pic.
    thanks
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
  12. Back To Top    #252
    Jun 2016
    FL
    901
    Quote Originally Posted by Captain 776 View Post
    thanks
    Captain, what bottom are you talking about?
  13. Back To Top    #253
    May 2016
    Thailand
    163
    Looks like they did a nice organized installation.
    The only comment I have is, I hope you do not ever have to replace a valve. Looks like they used socket x socket valves instead of valves with unionized ends. They have the piping so close together, it will be a major piping job if you ever need to replace a valve.
    My builder used the cheapest socket x socket valves, then 2 went bad, one started leaking at the handle and the other took a Gorilla to be able to turn it. I had to fabricate a whole new header to fix them and install valves with union ends. If you have valves with union ends, you can just loosen the locknut and slide the valve out and replace, no cutting or repiping.
    it may never happen to you.........hopefully
    thanks
    Bruce
  14. Back To Top    #254
    May 2016
    Thailand
    163
    Another of my Lessons Learned.
    After they complete grouting and cleaning your tile and BEFORE you begin filling, check the tile carefully, make sure it is grouted well and more importantly make sure the tile is clean, if you rub your fingers on the tile you should not get white finger tips or see where you rubbed your finger.
    my tile job and fill WAS done before I moved into the new house, they did not do a good job cleaning the grout off the tiles, they had a haze on them that you don't really see unless you are in the pool with a mask or the sun shines on it just right.
    I first thought it was the beginning of algae but it was haze from the grout.
    I drained 60-70% of the water and 3 of us got in there and scrubbed every tile by hand with stiff bristled nylon brushes, wash n rinse, wash n rinse.........then refill.
    We used a submersible pump during washing and rinsing so as not to get get of the dirt and debris in the permanent system.......it wasn't fun, but ever since my tiles sparkle.
    learn from my misfortune........make sure they clean all the grout and grout haze off.
    Also make sure the piping from the main drain is always plugged or capped during construction so you are not getting any of it in your piping system
  15. Back To Top    #255
    May 2016
    Thailand
    163
    Quote Originally Posted by grumpiebk View Post
    Please disregard, I may have responded to you when I meant to respond to a different picture
    Please disregard, I may have responded incorrectly to a different picture
    What material is this in the picture above in Post # 20
  16. Back To Top    #256
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,767
    It's Prism Matrix by Wet Edge. It's a pebble plaster finish.
    That photo was from another forum member's pool.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
  17. Back To Top    #257
    Jun 2016
    FL
    901
    Got my TF100 test kit today. Tested our source/fill water from our hose bib. Here are the results:
    Ph - 7.8
    TA - 70
    CH - 150
    FC - 0 - never turned pink
    CC - never turned pink
    For the TA test it never really turned red but more of a pink (first at 7 drops). I kept going and it never went red. Here are some pics of color:
    Ph:
    TA:
    CH:
    Anything look off or concerning?
  18. Back To Top    #258
    Jul 2012
    Tallahassee, FL
    31,504
    Looks great to me! You are blessed with that water.
    TA-it more of "a change of color towards red" which equals red"ish" which can end up pink. Once you get the change of color add one more drop to see if it changes more. If it does not change any more you do not count the last drop.
    Your CH is low for a pool BUT don't go buy anything. Your PB should supply the stuff to get the water balanced. I WOULD talk to him about your fill water tests and show him the TFP suggested range and see what he says.
    Kim
  19. Back To Top    #259
    Jun 2016
    FL
    901
    Quote Originally Posted by kimkats View Post
    Thanks Kim. Curious to learn - what are common fill water results that would be unfavorable, or not "blessed"? Will any of these results indicate how much green we should expect when we fill? I know certainly there are a lot of factors but how much does the fill water impact that and what reading is the best indication of what to expect?
  20. Back To Top    #260
    Jun 2016
    FL
    901
    Automation system electrical is getting taken care of today. I have the Pentair ET8. Is there any value in having the two pool lights run independent of each other? I already have the spa and shelf separate from the pool. We will have two extra relays left over after our landscape lighting is added.
    Since we have decking on the side of the pool and the lights are also on the sides of the pool this may allow us to turn off the light facing the patio should we be entertaining in that space at night. Not sure it's that big of a deal tho.
