Page 10 of 40 FirstFirst ... 7891011121320 ... LastLast
Results 181 to 200 of 798
Thread: South Florida Pool & Outdoor Living - STARTUP PHASE
  1. Back To Top    #181
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,817
    Re: South Florida Pool & Outdoor Living - DIG Phase
    Yeah, probably not coordinated. As long as there is other concrete work besides the columns (decking?) then it doesn't really matter since concrete delivery will be back on site again.
    Even so, my motto on those things is best not to meddle.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  2. Back To Top    #182
    Jun 2016
    FL
    901
    So the gunite is done! It seemed like a fast, clean job. We love how it looks. And I am happy with the size. I was afraid it was going to start shrinking on us. But it is perfect for our family and our yard. I don't ever think we wish we went bigger and will certainly never wish it was smaller.
    We had a couple of minor misses - white umbrella sleeves in the shelf instead of grey and a missing sleeve in the far side bench. But the PB said these are easily fixable. The only noticeable concern was how steep the steps are at 12". From other posts on this site it may not be a huge deal but with the pool empty they look huge! I also immediately brought this attention to our PB before the gunite crew left. He assured me it's not as bad as it looks once water is in it.
    As for the patio, the beams are up. Boy is the patio large! We unfortunately lost our full overhead view of pool progress due to the beams, but it is worth it to see our vision coming together!
    Here are the pics:
    Brian - UNDER CONSTRUCTION: 17K gal SW Gunite IG. 17'x23'(w/shelf)x34'. 650sf. 114' perim. 3.5'-5' depth sports pool. 7'x11' sun shelf, 6'x8' spa. Intelliflow VSP, IC60 SWCG, CC420 filter, 4 LEDs (2 Globrite and 2 Intellibrite). Hayward 140K BTU heat pump. Pentair EasyTouch 8 automation. Ivory travertine deck. 8"X16" travertine coping. NPT lightwaves Aquamarine spa tile and marker tiles. Undecided on plaster/pebble finish.
  3. Back To Top    #183
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    SWEET! Love how it looks. Those stairs do look big. How much is a "normal" step?
    Glad to hear the oppsies are easy to fix.
    Kim
  4. Back To Top    #184
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    7" is a normal riser height for a staircase. 12" in a pool is very typical and should not be of concern.
    The umbrella sleeves have collars that the plaster crew will install. These will be the colored portion that shows.
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
  5. Back To Top    #185
    Jun 2016
    FL
    901
    Thanks for the insight, Brian. It makes me feel a little better. I am honestly more concerned about the little ones being able to get in and out ok. I think it also is a bit deceiving in the pics because the bottom step is larger than 12" as it gets closer to the shelf (it's probably 10' end to end).
  6. Back To Top    #186
    Jun 2016
    FL
    901
    Quote Originally Posted by bdavis466 View Post
    7"The umbrella sleeves have collars that the plaster crew will install. These will be the colored portion that shows.
    Will they just core drill the other holder that they missed today?
  7. Back To Top    #187
    Apr 2016
    Orlando, FL
    57
    Looks great Brian! Awesome layout from the wide spa, wrap around steps, and the amount bench seating. Now that the shell is in, what do you think of the benches? From the pics, it looks like the perfect amount of seating.
    - Alex
    My build thread: -Central FL pool build
    Gray Harbor Aqua Pearl Mini Pebble Pics - Gray Harbor Mini Pebble - Lots of Pics
  8. Back To Top    #188
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    Quote Originally Posted by grumpiebk View Post
    Or chip a hole... Either way no big deal.
    -Brian-
    POOL BUILD
  9. Back To Top    #189
    Jun 2016
    FL
    901
    Quote Originally Posted by CCCentralFL View Post
    - Alex
    Thanks, Alex. We love how it all came together and I love the late bench addition. Our design was for a sun shelf that was connected to the steps, but not actually the steps themselves. So the wraparound stairs give a separate area to hang out from the shelf. Think kids on the shelf or kids on the stairs while adults can still do their thing in the other spot. Since we have the large covered patio addition, the far side bench offers some seating facing back to the patio and also an area where we often project movies and football games. It also gives some spa side seating and an access point to climb out of the pool to hop in the spa and vice versa.
    I am anxiously looking forward to patio decking which will really tie the projects together. Right now there is concrete, dirt, and wood everywhere. But I guess that's par for the course.
  10. Back To Top    #190
    Jul 2012
    Tallahassee, FL
    30,464
    The bigger the mess the more you will appreciate it all when it is done LOL
    Kim
  11. Back To Top    #191
    Jun 2016
    FL
    901
    How frequently and for how long (each time) should I be watering the shell?
  12. Back To Top    #192
    Jan 2016
    Mesa, Az
    541
    You want to keep it damp. If there's direct sun or a lot of wind it will dry out quicker and you need to spray more often. Two or three times a day is usually sufficient. A sprinkler can assist, but complete coverage is not assured. You're just trying to avoid the free water in the concrete matrix leaving to soon and causing shrinkage cracks. Keeping free water available for the hydration reaction is key as well. Concrete doesn't "dry" it "cures".
  13. Back To Top    #193
    Jun 2016
    FL
    901
    Thanks, Big E. My pool builders response when I asked if I should water it: a couple of time a week won't hurt. For some bizarre reason I like your more descriptive and technical answer!
  14. Back To Top    #194
    Jun 2016
    FL
    901
    Re: South Florida Pool & Outdoor Living - GUNITE PHASE
    Another Saturday morning surprise! Removing wood frame, backfilling, grading and digging plumbing trenches today. Also, the patio trusses and most of the plywood sheathing is up. Finally I can actually see the pool from our living room! Previously piles of dirt blocked our view from the patio footer dig.
  15. Back To Top    #195
    Jul 2012
    Tallahassee, FL
    30,464
    Love the surprises! Getting closer!
    Kim
  16. Back To Top    #196
    Jun 2016
    FL
    901
    Curious, how does the PB clean out all of the dirt and gunite debris from the shell before plaster/finish? Is that what the hole in the gunite floor is for (not the drain)? These are the things I ponder as I bond with our pool.
  17. Back To Top    #197
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,742
    They'll scrape it off and wash everything down. It's not nearly as difficult as it may appear to be right now.
    -Brian-
    POOL BUILD
  18. Back To Top    #198
    Jun 2016
    FL
    901
    It's been relatively unexciting the last few days. Plumbing and pool lighting electric was run. Coping (8"x16" ivory travertine) and spa tile showed up today so that's probably getting done before the end of the week.
  19. Back To Top    #199
    Jul 2012
    Tallahassee, FL
    30,464
    Unexciting but oh so neat in that it is that much closer to being done!!!
    Kim
  20. Back To Top    #200
    Jun 2016
    FL
    901
    Turns out our plumbing to the pad is mislocated by about 3 feet as compared to plans. Usually this wouldnt be a big deal, but we had plans to use most of that encroached space for outdoor storage and our garbage cans. When I informed the PB of this, he responded that it needed to located in its current location due to the proximity of the electrical box on the side of our house (it is empty currently but was added by the builder for an eventual pool). The box is currently about 5-6 feet from where they put the plumbing that comes out of the ground for the pad. I am not familiar with electrical or plumbing code, so does this sound accurate? I want to make sure I am not getting the "I dont want to fix it" runaround.
