Dear David:
Thank you for your email. The procedure for the FAS-DPD method instructs
the test kit user to:
Add 2 dippers R-0870 DPD Powder. Swirl until dissolved. Sample will turn
pink if free chlorine is present.
NOTE: If pink color disappears, add R-0870 DPD Powder until color turns
pink.
If you only add one scoop you may not be adding enough indicator to
obtain the appropriate result. The scoops do not need to be measured
exactly, but two scoops should be added. The note indicates adding
excess is fine within reason. This drop test kit has an accuracy set at
one drop in 10. That means that for a reading of 2 ppm your true answer
could range from 1.5-2.5 ppm (with drop equivalence = 0.5 for 10 mL
sample). In all of Taylor's three-quarter and two ounce bottles, the tip
is drilled to deliver 24 drops per mL (+ or - one drop).
Sincerely,
Jarad Proctor
Customer Service Representative, Technical Support
TAYLOR TECHNOLOGIES, INC.
31 Loveton Circle, Sparks, MD 21152-9206
800-TEST KIT (837-8548), ext.127
410-771-4291 FAX
[email protected]
-----Original Message-----
Sent: Wednesday, June 03, 2009 10:34 PM
To: Jarad Proctor
Subject: Message from 'EmailDirectory' from Website
TaylorTechnologies.com
Email Address: email address deleted
Message: Hello Jarad,
I have a question about the FAS-DPD free chlorine test. When using the
R-0870 powder, is the measurement of the powder critical for obtaining
accurate, repeatable test results? I assume using too little would not
produce an accurate result, but can you use too much?
The reason I ask is that I have been getting variability in repeat tests
using the same water sample taken from my pool. The instructions I got
with my kit suggested using 1 scoop of R-0870 powder per 10mL of water
to be tested. However, the container of powder that came with my kit
contains both a fine powder and larger chunks. I've noticed that when I
measure the powder using mainly the larger pieces the test water turns a
lighter shade of pink than when measuring with the fine powder, thus
giving unreliable test results.
I'm thinking that you really can't use too much of the powder(within
reason), is that correct? So maybe using 2 scoops would yield a more
reliable result?
Pardon me if I have contacted you erroneously, and if so, please forward
this email to the proper channel.
Thanks for your time,
David
