Thread: Every other minute or so Bubbles shoot out...
    Of my return jets. It only last for like 10 seconds and then it's back to normal. Also when the bubbles thing happens it sounds as if my filter is kinda surging or something. I guess this means I have some kind of air leak huh? Is that harmful to equipment.
    Thanks
    20,000 Gal.
    Hayward D.E.
    I.G.
    All day Sun.
    Feb 2008
    Denton, TX
    5,061
    Re: Every other minute or so Bubbles shoot out...
    When you hear your pump "surging", do you notice at the time that air appears in your strainer basket on the pump?
    It sounds as though you might have a suction side leak somewhere, this being in the equipment coming from your pool to the pump. Air bubbles in the returns and loss of pump prime can indicate this.
    Make sure that the lid on your strainer basket is snug and that the O-ring seals well.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    488
    That sounds like an air leak on the suction side of the pump. Could be the pump strainer cap is leaking, check the drain plug on the inlet strainer, maybe the pool level is low and you are getting air from the skimmer, or maybe the inlet line to the pump has a crack or leak. If you have a gate valve on the inlet line check the packing nut. If it's real loose you could be sucking air though the valve.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Thanks for the suggestions. No the water level is not low. As far as the pump strainer, I will check when I get home from work. I hope it is not an underground piping leak.....
    20,000 Gal.
    Hayward D.E.
    I.G.
    All day Sun.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by catagory5
    It is usually not an underground piping leak, although it can be. Generally, suction side leaks are the result of a loss of proper seal. Examples include the strainer basket lid which was mentioned, or a jandy valve that requires a new gasket or needs to be replaced.
    When you have the time, you can attempt to isolate the problem by checking the strainer basket lid and O-ring and if that doesn't fix it, try different suction settings on your valves. For example, try shutting your skimmers off and open only the floor drain. Then try the skimmers only and close the floor drain. Sometimes you just have to monkey around with things to see what changes. Let us know what you find out.
