victoria4504 said:These are the results of my good kit. I received the TF-100 test kit yesterday. I used the cal-hypo (Shock & Swim) last night. I have some dirt/stuff in the bottom of the pool so I'll vacuum today to see if that helps with the cloudiness. Usually when I vacuum the pool I backwash the filter after. Is this okay?
Vicky
BRAINFART. Sorry, I didn't even read up above for a refresher. It's early, I'm PMSing and didn't sleep well. Forgive me!
Sounds like a plan. It could be cloudiness from the cal-hypo too, but there is still a chance you'll need to raise it up to shock level. Tonight, after you add bleach, perform the Overnight FC test, instructions here. If the FC doesn't hold overnight, you'll need to shock.
