Low voltage lighting, fountain for Pentair IS9
teeroy
May 31, 2009
2
I would like to hook up low voltage lighting and a fountain to my Pentair IS9. Would somebody be able to provide some high level direction on how to go about doing this? I can do the detailed research once I know the basic direction that I need to head in.
Thanks.
Hi, I should have posted some links. Also, I got the model wrong, it is an I9+3S. Mine is the one that has the built-in Sub Panel.
I took a look at my indoor control panel and I only have two "devices" available for programming. The rest are taken up between the pool and spa light, the spa jets, spillway, pool pump, cleaner, etc. So I guess that means that I can only control two more devices.
I am pre-plumbed for solar but haven't had solar installed yet. Assuming that will take up at least one control port then I probably only have one available. My guess is that means I probably won't be able to hook up my low voltage lighting. If not that should be OK as I can just use the standard light sensors on those. Would be nice to hook up my fountain to it, though, so it doesn't run 24hours a day like it is now. Note that my fountain is just a normal patio fountain with one of the little pumps that plugs into 110V so it isn't a fountain that uses a normal pool pump.
Direct link to user manual:
http://www.pentairpool.com/pdfs/IntelliTouchLoadCtrIG.pdf
Link to Pentair user manual page for more manuals:
http://www.pentairpool.com/techinfo/datasheets3.php?d=2&s=5
